Change the VRF instance as required to configure a Circuitless IPv6 interface on a specific VRF instance.
You can use a circuitless IPv6 (CLIPv6) interface to provide uninterrupted connectivity to your system.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6.
  3. Select the Circuitless IP tab.
  4. Select Insert.
  5. In the Interface field, assign a CLIP interface number.
  6. Type the IPv6 address and prefix length.
  7. Select Insert.
Circuitless IPv6 Field Descriptions
Use the data in the following table to use the Circuitless IPv6 tab.
Name
Description
Interface
Specifies the interface to which this entry applies.
Addr
Specifies the IPv6 address to which this entry applies.
AddrLen
Specifies the prefix length value for this address. You cannot change the address length after you create it. You must provide this value to create an entry in this table.
Name
Note:
This field does not apply to all hardware platforms.
Specifies the name assigned to the IPv6 CLIP address.
